Non-uniform source modeling for Distributed Video Coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a novel correlation model, called predictive Binary Symmetric Channel (BSC), for Distributed Source Coding (DSC). We then consider non-uniform binary sources and show that, for the predictive BSC model, the non-uniformity does not reduce the compression rate in asymmetric DSC. We assess the minimum achievable rate loss induced by a mismatch between the assumed and the true correlation models. We also propose an LDPC-based decoder adapted to both the classical (additive) BSC and the new (predictive) BSC correlation models. Finally, for Distributed Video Coding (DVC) application, we propose a criterion that allows us to switch between the two correlation models.
Toto-Zarasoa_-_Roumy_-_Guillemot_-_Non-uniform_source_modeling_for_Distributed_Video_Coding.pdf (809.42 Ko) Télécharger le fichier
inria-00538790 , version 1 (23-11-2010)
  • HAL Id : inria-00538790 , version 1
Velotiaray Toto-Zarasoa, Aline Roumy, Christine Guillemot. Non-uniform source modeling for Distributed Video Coding. 18th European Signal Processing Conference, Aug 2010, Aalborg, Denmark. ⟨inria-00538790⟩
197 Consultations
76 Téléchargements
