Set constraints and automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information and Computation Année : 1999
We define a new class of automata which is an acceptor model for mappings from the set of terms T? over a ranked alphabet ? into a set E of labels. When E is a set of tuples of binary values, an automaton can be viewed as an acceptor model for n-tuples of tree languages. We prove decidability of emptiness and closure properties for this class of automata. As a consequence of these results, we prove decidability of satisfiability of systems of positive and negative set constraints without projection symbols. We prove the decidability of the satisfiability problem for systems of positive and negative set constraints without projection symbols. Moreover we prove that a non-empty set of solutions always contain a regular solution (i.e., a n-tuple of regular tree languages). We also deduce decidability results for properties of sets of solutions of systems of set constraints.
Fichier non déposé
inria-00538886 , version 1 (23-11-2010)
  • HAL Id : inria-00538886 , version 1
Rémi Gilleron, Sophie Tison, Marc Tommasi. Set constraints and automata. Information and Computation, 1999, 149 (1), pp.1--41. ⟨inria-00538886⟩
70 Consultations
0 Téléchargements
