Localisable moving average symmetric stable and multistable processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Models Année : 2009
We study a particular class of moving average processes which possess a property called localisability. This means that, at any given point, they admit a “tangent process”, in a suitable sense. We give general conditions on the kernel g defining the moving average which ensures that the process is localisable and we characterize the nature of the associated tangent processes. Examples include the reverse Ornstein-Uhlenbeck process and the multistable reverse Ornstein-Uhlenbeck process. In the latter case, the tangent process is, at each time t, a Lévy stable motion with stability index possibly varying with t. We also consider the problem of path synthesis, for which we give both theoretical results and numerical simulations.
MA-CS1RevisedSMDoubleSpaced.pdf (364.2 Ko) Télécharger le fichier
inria-00538980 , version 1 (23-11-2010)
Kenneth J. Falconer, Ronan Le Guével, Jacques Lévy Véhel. Localisable moving average symmetric stable and multistable processes. Stochastic Models, 2009, 25 (4), pp.648-672. ⟨10.1080/15326340903291321⟩. ⟨inria-00538980⟩
112 Consultations
132 Téléchargements
