inria-00539899, version 1
Formal Verification of Consensus Algorithms in a Proof Assistant
Henri Debrat a, 1Bernadette Charron-Bost b, 2Stephan Merz
1
2010 Grande Region Security and Reliability Day (2010)
Résumé : Consensus is regarded as the fundamental problem that must be solved to implement a fault-tolerant distributed system. It requires nodes to eventually agree on a common value among the initial values held by each of them. Agreement should be reached despite the failures of some components (process or link). Depending on the timing and failure models, numerous Consensus algorithms have been proposed in the literature. We are studying techniques for proving the correctness of these algorithms using the interactive proof assistant Isabelle, aiming for a high level of automation.
- a – Nancy-University
- b – CNRS
- 1 : VERIDIS (INRIA Lorraine)
- INRIA
- 2 : Laboratoire d'informatique de l'école polytechnique (LIX)
- CNRS : UMR7161 – Polytechnique - X
- Domaine : Informatique/Logique en informatique
- Mots-clés : consensus algorithm – formal verification – proof assistant
- inria-00539899, version 1
- http://hal.inria.fr/inria-00539899
- oai:hal.inria.fr:inria-00539899
- Contributeur : Stephan Merz
- Soumis le : Jeudi 25 Novembre 2010, 14:42:43
- Dernière modification le : Lundi 29 Novembre 2010, 09:17:38
Documents associés
Exporter
