Non-Linear Polynomial Selection for the Number Field Sieve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2012
We present an algorithm to find two non-linear polynomials for the Number Field Sieve integer factorization method. This algorithm extends Montgomery's "two quadratics" method; for degree 3, it gives two skewed polynomials with resultant O(N5/4), which improves on Williams O(N4/3) result.
polyselect.pdf (138.72 Ko) Télécharger le fichier
inria-00540483 , version 1 (26-11-2010)
  • HAL Id : inria-00540483 , version 1
Thomas Prest, Paul Zimmermann. Non-Linear Polynomial Selection for the Number Field Sieve. Journal of Symbolic Computation, 2012, 47 (4), pp.401-409. ⟨inria-00540483⟩
460 Consultations
391 Téléchargements
