Intrinsically Motivated Goal Exploration for Active Motor Learning in Robots: a Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce the Self-Adaptive Goal Generation - Robust Intelligent Adaptive Curiosity (SAGG-RIAC) algorithm as an intrinsically motivated goal exploration mechanism which allows a redundant robot to efficiently and actively learn its inverse kinematics. The main idea is to push the robot to perform babbling in the goal/operational space, as opposed to motor babbling in the actuator space, by self-generating goals actively and adaptively in regions of the goal space which provide a maximal competence improvement for reaching those goals. Then, a lower level active motor learning algorithm, inspired by the SSA algorithm, is used to allow the robot to locally explore how to reach a given self-generated goal. We present simulated experiments in a 32 dimensional continuous sensorimotor space showing that 1) exploration in the goal space can be a lot faster than exploration in the actuator space for learning the inverse kinematics of a redundant robot; 2) selecting goals based on the maximal improvement heuristics is statistically significantly more efficient than selecting goals randomly.
BaranesOudeyerIROS10.pdf (397.05 Ko) Télécharger le fichier
inria-00541769 , version 1 (01-12-2010)
  • HAL Id : inria-00541769 , version 1
Adrien Baranes, Pierre-Yves Oudeyer. Intrinsically Motivated Goal Exploration for Active Motor Learning in Robots: a Case Study. IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS 2010), 2010, Taipei, Taiwan. ⟨inria-00541769⟩
110 Consultations
532 Téléchargements
