Maturationally-Constrained Competence-Based Intrinsically Motivated Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper studies the coupling of intrinsic motiva- tion and physiological maturational constraints, and argues that both mechanisms may have complex bidirectional interactions allowing to actively control the growth of complexity in motor development. First, we introduce the self-adaptive goal generation algorithm (SAGG), instantiating an intrinsically motivated goal exploration mechanism for motor learning of inverse models. Then, we introduce a functional model of maturational con- straints inspired by the myelination process in humans, and show how it can be coupled with the SAGG algorithm, forming a new system called McSAGG. We then present experiments to evaluate qualitative properties of these systems when applied to learning a reaching skill with an arm with initially unknown kinematics.
BaranesOudeyerICDL10.pdf (817.44 Ko) Télécharger le fichier
inria-00541770 , version 1 (01-12-2010)
  • HAL Id : inria-00541770 , version 1
Adrien Baranes, Pierre-Yves Oudeyer. Maturationally-Constrained Competence-Based Intrinsically Motivated Learning. IEEE International Conference on Development and Learning (ICDL 2010), 2010, Ann Arbor, United States. ⟨inria-00541770⟩
186 Consultations
289 Téléchargements
