Acroban the Humanoid: Playful and Compliant Physical Child-Robot Interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Compliance and semi-passive dynamics in the framework of humanoid robot locomotion Advantages of a multi-articulated vertebral column in dynamic semi-passive motor primitives Natural playful child-robot physical interaction The illusion of life: dynamic movement, touch and the Luxo Jr. effect
Acroban_the_humanoid-siggraph.pdf (58.8 Ko) Télécharger le fichier
LyOudeyerSiggraph2010.pdf (6.6 Mo) Télécharger le fichier
Format : Autre
inria-00541786 , version 1 (16-12-2010)
  • HAL Id : inria-00541786 , version 1
Olivier Ly, Pierre-Yves Oudeyer. Acroban the Humanoid: Playful and Compliant Physical Child-Robot Interaction. ACM SIGGRAPH'2010 Emerging Technologies, 2010, Los Angeles, United States. ⟨inria-00541786⟩
136 Consultations
87 Téléchargements
