Under-Determined Reverberant Audio Source Separation Using Local Observed Covariance and Auditory-Motivated Time-Frequency Representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the local Gaussian modeling framework for under-determined convolutive audio source separation, where the spatial image of each source is modeled as a zero-mean Gaussian variable with full-rank time- and frequency- dependent covariance. We investigate two methods to improve the accuracy of parameter estimation, based on the use of local observed covariance and auditory-motivated time-frequency representation. We derive an iterative expectation-maximization (EM) algorithm with a suitable initialization scheme. Experimental results over stereo synthetic reverberant mixtures of speech show the effectiveness of the proposed methods.
2010_LVA_DuongEtAl.pdf (201.7 Ko) Télécharger le fichier
inria-00541868 , version 1 (05-02-2011)
Ngoc Q. K. Duong, Emmanuel Vincent, Rémi Gribonval. Under-Determined Reverberant Audio Source Separation Using Local Observed Covariance and Auditory-Motivated Time-Frequency Representation. Latent Variable Analysis and Signal Separation, 9th International Conference on, Sep 2010, Saint-Malo, France. pp.73--80, ⟨10.1007/978-3-642-15995-4_10⟩. ⟨inria-00541868⟩
312 Consultations
277 Téléchargements
