Organization of Information for the Web using Hierarchical Fuzzy Clustering Algorithm based on Co-Occurrence Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a Hierarchical Fuzzy Clustering algorithm which uses domain knowledge to automatically determine the number of clusters and their initial values. The algorithm is applied on a collection of web pages and the results are compared with existing algorithms in the literature.
WI2010.pdf (1.6 Mo) Télécharger le fichier
inria-00542691 , version 1 (03-12-2010)
Faraz Zaidi, Guy Melançon. Organization of Information for the Web using Hierarchical Fuzzy Clustering Algorithm based on Co-Occurrence Networks. WI-IAT '10, 2010, Toronto, Canada. pp.421-424, ⟨10.1109/WI-IAT.2010.86⟩. ⟨inria-00542691⟩
272 Consultations
210 Téléchargements
