Semantic Join Point Models: Motivations, Notions and Requirements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Aspect-oriented programming (AOP) has been designed to provide a better separation of concerns at development level by modularizing concerns that would otherwise be tangled and scattered across other concerns. Current mainstream AOP techniques separate crosscutting concerns on a syntactic basis whereas a concern is more a semantic matter. Therefore, a different, more semanticoriented, approach to AOP is needed. In this position paper, we investigate the limitations of mainstream AOP techniques, mainly AspectJ, in this regard and highlight the issues that need to be addressed to design semantic-based join point models.
Cazzola06a.pdf (99.14 Ko) Télécharger le fichier
inria-00542782 , version 1 (03-12-2010)
  • HAL Id : inria-00542782 , version 1
Walter Cazzola, Jean-Marc Jézéquel, Awais Rashid. Semantic Join Point Models: Motivations, Notions and Requirements. SPLAT 2006 (Software Engineering Properties of Languages and Aspect Technologies), 2006, Bonn, Germany, Germany. ⟨inria-00542782⟩
130 Consultations
383 Téléchargements
