Improving Test Suites for Efficient Fault Localization
The need for testing-for-diagnosis strategies has been identified for a long time, but the explicit link from testing to diagnosis (fault localization) is rare. Analyzing the type of information needed for efficient fault localization, we identify the attribute (called Dynamic Basic Block) that restricts the accuracy of a diagnosis algorithm. Based on this attribute, a test-for-diagnosis criterion is proposed and validated through rigorous case studies: it shows that a test suite can be improved to reach a high level of diagnosis accuracy. So, the dilemma between a reduced testing effort (with as few test cases as possible) and the diagnosis accuracy (that needs as much test cases as possible to get more information) is partly solved by selecting test cases that are dedicated to diagnosis.
Génie logiciel [cs.SE]
