Uniform and non-uniform random generation of RNA secondary structures with pseudoknots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We give an efficient algorithm to generate random RNA secondary structures with pseudoknots, either uniformly or non uniformly in a controllable fashion. Although we consider a restrictive class of pseudoknots, the class of {\em simple recursive pseudoknots}, it turns out that most of the known real RNA pseudoknotted secondary structures in the biological databases belong to this class.
SaWaDe2010.pdf (1.12 Mo) Télécharger le fichier
inria-00543315 , version 1 (06-12-2010)
  • HAL Id : inria-00543315 , version 1
Cédric Saule, Claire Wallon, Alain Denise. Uniform and non-uniform random generation of RNA secondary structures with pseudoknots. GASCOM, Sep 2010, Montreal, Canada. ⟨inria-00543315⟩
273 Consultations
44 Téléchargements
