Application of the linear sampling method to retrieve cracks with impedance boundary conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We use the Linear Sampling Method (LSM) to detect a crack with impedance boundary conditions. This paper extends the work of Cakoni and Colton [1] that uses the LSM to reconstruct a crack with mixed boundary conditions from measurements of the far field patterns associated with different incident plane waves. The performance of our method is illustrated through some numerical examples.
RR-7478.pdf (2.47 Mo) Télécharger le fichier
inria-00543901 , version 1 (06-12-2010)
  • HAL Id : inria-00543901 , version 1
Fahmi Ben Hassen, Yosra Boukari, Houssem Haddar. Application of the linear sampling method to retrieve cracks with impedance boundary conditions. [Research Report] RR-7478, INRIA. 2010. ⟨inria-00543901⟩
260 Consultations
202 Téléchargements
