Napier's ideal construction of the logarithms
This report explains the construction of logarithms by Napier, and provides reconstructions of the 1614 and 1616 tables.
napier1619construction.pdf (1.29 Mo)
Télécharger le fichier
napier1614doc.pdf (578.22 Ko)
napier1614idealdoc.pdf (555.46 Ko)
napier1616doc.pdf (556.28 Ko)
Format : Autre
Format : Autre
Format : Autre
