A roadmap towards versatile MIR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most MIR systems are specifically designed for one application and one cultural context and suffer from the semantic gap between the data and the application. Advances in the theory of Bayesian language and information processing enable the vision of a versatile, meaningful and accurate MIR system integrating all levels of information. We propose a roadmap to collectively achieve this vision.
vincent_ISMIR10.pdf (80.47 Ko) Télécharger le fichier
inria-00544047 , version 1 (07-12-2010)
  • HAL Id : inria-00544047 , version 1
Emmanuel Vincent, Stanislaw A. Raczynski, Nobutaka Ono, Shigeki Sagayama. A roadmap towards versatile MIR. 2010 Int. Society for Music Information Retrieval Conf. (ISMIR), Aug 2010, Utrecht, Netherlands. pp.662--664. ⟨inria-00544047⟩
254 Consultations
130 Téléchargements
