Robust modeling of musical chord sequences using probabilistic N-grams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The modeling of music as a language is a core issue for a wide range of applications such as polyphonic music retrieval, automatic style identification, audio to symbolic music transcription and computer-assisted composition. In this paper, we focus on the modeling of chord sequences by probabilistic N-grams. Previous studies using these models have achieved limited success, due to overfitting and to the use of a single chord labeling scheme. We investigate these issues using model smoothing and selection techniques initially designed for spoken language modeling. This approach is evaluated over a set of songs by The Beatles, considering several chord labeling schemes. Initial results show that the accuracy of N-grams is increased but that additional improvements may still be achieved in the future using more advanced, possibly music-specific, smoothing techniques.
scholz_ICASSP09.pdf (108.4 Ko) Télécharger le fichier
inria-00544166 , version 1 (07-12-2010)
  • HAL Id : inria-00544166 , version 1
Ricardo Scholz, Emmanuel Vincent, Frédéric Bimbot. Robust modeling of musical chord sequences using probabilistic N-grams. 2009 IEEE Int. Conf. on Acoustics, Speech and Signal Processing (ICASSP), Apr 2009, Taipei, Taiwan. pp.53--56. ⟨inria-00544166⟩
141 Consultations
503 Téléchargements
