s'authentifier
version française rss feed
inria-00544199, version 1
First stereo audio source separation evaluation campaign: data, algorithms and results
Emmanuel Vincent () a1, Hiroshi Sawada 2, Pau Bofill 3, Shoji Makino 2, Justinian Rosca 4
7th Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA) (2007) 552--559
Résumé : This article provides an overview of the first stereo audio source separation evaluation campaign, organized by the authors. Fifteen underdetermined stereo source separation algorithms have been applied to various audio data, including instantaneous, convolutive and real mixtures of speech or music sources. The data and the algorithms are presented and the estimated source signals are compared to reference signals using several objective performance criteria.
  • Domaine : Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • inria-00544199, version 1
  • oai:hal.inria.fr:inria-00544199
  • Contributeur :
  • Soumis le : Mardi 7 Décembre 2010, 14:51:35
  • Dernière modification le : Jeudi 9 Décembre 2010, 10:53:34
tous les articles de la base du CCSd...
