Object-coding for resolution-free musical audio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Object-based coding of audio represents the signal as a parameter stream for a set of sound-producing objects. Encoding in this manner can provide a resolution-free representation of an audio signal. Given a robust estimation of the object-parameters and a multi-resolution synthesis engine, the signal can be "intelligently" upsampled, extending the bandwidth and getting best use out of a high-resolution signal-chain. We present some initial findings on extending bandwidth using harmonic models.
welburn_AES07.pdf (145.03 Ko) Télécharger le fichier
inria-00544224 , version 1 (13-10-2011)
  • HAL Id : inria-00544224 , version 1
Stephen J. Welburn, Mark D. Plumbley, Emmanuel Vincent. Object-coding for resolution-free musical audio. 31st AES Int. Conf. on new directions in high resolution audio, Jun 2007, London, United Kingdom. ⟨inria-00544224⟩
127 Consultations
112 Téléchargements
