s'authentifier
version française rss feed
inria-00544265, version 1
Low bitrate object coding of musical audio using bayesian harmonic models
Emmanuel Vincent 1, Mark D. Plumbley 1
IEEE Transactions on Audio, Speech, and Language Processing 15, 4 (2007) 1273--1282
Résumé : This article deals with the decomposition of music signals into pitched sound objects made of harmonic sinusoidal partials for very low bitrate coding purposes. After a brief review of existing methods, we recast this problem in the Bayesian framework. We propose a family of probabilistic signal models combining learnt object priors and various perceptually motivated distortion measures. We design efficient algorithms to infer object parameters and build a coder based on the interpolation of frequency and amplitude parameters. Listening tests suggest that the loudness-based distortion measure outperforms other distortion measures and that our coder results in a better sound quality than baseline transform and parametric coders at 8 kbit/s and 2 kbit/s. This work constitutes a new step towards a fully object-based coding system, which would represent audio signals as collections of meaningful note-like sound objects.
  • Domaine : Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • inria-00544265, version 1
  • oai:hal.inria.fr:inria-00544265
  • Contributeur :
  • Soumis le : Mardi 7 Décembre 2010, 15:41:05
  • Dernière modification le : Mercredi 8 Décembre 2010, 15:14:05
tous les articles de la base du CCSd...
