Underdetermined source separation with structured source priors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We consider the source extraction problem for stereo instantaneous musical mixtures with more than two sources. We prove that usual separation methods based only on spatial diversity have performance limitations when the sources overlap in the time-frequency plane. We propose a new separation scheme combining spatial diversity and structured source priors. We present possible priors based on nonlinear Independent Subspace Analysis (ISA) and Hidden Markov Models (HMM), whose parameters are learnt on solo musical excerpts. We show with an example that they actually improve the separation performance.
vincent_ICA04.pdf (353.85 Ko) Télécharger le fichier
inria-00544694 , version 1 (08-12-2010)
  • HAL Id : inria-00544694 , version 1
Emmanuel Vincent, Xavier Rodet. Underdetermined source separation with structured source priors. 5th Int. Conf. on Independent Component Analysis and Blind Signal Separation (ICA), Sep 2004, Granada, Spain. pp.327--332. ⟨inria-00544694⟩
Collections
IRCAM
49 Consultations
226 Téléchargements
