Circularity measuring in linear time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new circularity measure inspired from Arkin [Arkin91], Latecki [Latecki00] tools of shape matching that is constructed in a tangent space. We then introduce a linear algorithm that uses this measure for circularity measuring. This method can also be regarded as a method for circular object recognition. Experimental results show the robustness of this simple method.
Circularity_25january.pdf (193.4 Ko) Télécharger le fichier
inria-00544736 , version 1 (10-12-2010)
  • HAL Id : inria-00544736 , version 1
Thanh Phuong Nguyen, Isabelle Debled-Rennesson. Circularity measuring in linear time. 20th International Conference on Pattern Recognition - ICPR 2010, Aug 2010, Isatanbul, Turkey. pp.2098-2101. ⟨inria-00544736⟩
114 Consultations
282 Téléchargements
