Single Viewpoint Stereoscopic Sensor Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Calibration is a classical issue in computer vision. This work presents a camera calibration approach for single viewpoint cameras which can be modeled by the unified spherical projection. The paper extends the method of perspective camera calibration using virtual visual servoing, to central cameras and particularly to omnidirectional cameras. The contribution is the development of intrinsic and extrinsic calibration of N central cameras stereo rig.
2010_isivc_caron.pdf (866.97 Ko) Télécharger le fichier
inria-00544783 , version 1 (10-12-2010)
  • HAL Id : inria-00544783 , version 1
Guillaume Caron, El Mustapha Mouaddib, Eric Marchand. Single Viewpoint Stereoscopic Sensor Calibration. Int. Symp. on Image/Video Communications over fixed and mobile networks, ISIVC-2010, 2010, Rabat, Morocco, Morocco. ⟨inria-00544783⟩
198 Consultations
194 Téléchargements
