Audio Source Separation With a Single Sensor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Audio, Speech and Language Processing Année : 2006
In this work we present a method to perform a complete audiovisual source separation without need of previous information. This method is based on the assumption that sounds are caused by moving structures. Thus, an efficient representation of audio and video sequences allows to build relationships between synchronous structures on both modalities. A robust clustering algorithm groups video structures exhibiting strong correlations with the audio so that sources are counted and located in the image. Using such information and exploiting audio-video correlation, the audio sources activity is determined. Next, spectral Gaussian Mixture Models (GMMs) are learnt in time slots with only one source active so that it is possible to separate them in case of an audio mixture. Audio source separation performances are rigorously evaluated, clearly showing that the proposed algorithm performs efficiently and robustly.
2006_IEEE_TSALP_BenaroyaBimbotGribonval_AudioSepOneSensor.pdf (412.37 Ko) Télécharger le fichier
inria-00544949 , version 1 (11-12-2010)
Laurent Benaroya, Frédéric Bimbot, Rémi Gribonval. Audio Source Separation With a Single Sensor. IEEE Transactions on Audio, Speech and Language Processing, 2006, 14 (1), pp.191--199. ⟨10.1109/TSA.2005.854110⟩. ⟨inria-00544949⟩
304 Consultations
1123 Téléchargements
