Blind Audiovisual Source Separation Based on Redundant Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Anna Llagostera Casanovas
  • Fonction : Auteur
  • PersonId : 884023
Gianluca Monaci
  • Fonction : Auteur
Pierre Vandergheynst
  • Fonction : Auteur
In this work we present a method to perform a complete audiovisual source separation without need of previous information. This method is based on the assumption that sounds are caused by moving structures. Thus, an efficient representation of audio and video sequences allows to build relationships between synchronous structures on both modalities. A robust clustering algorithm groups video structures exhibiting strong correlations with the audio so that sources are counted and located in the image. Using such information and exploiting audio-video correlation, the audio sources activity is determined. Next, \backslashemph\char123spectral\char125 GMMs are learnt in time slots with only one source active so that it is possible to separate them in case of an audio mixture. Audio source separation performances are rigorously evaluated, clearly showing that the proposed algorithm performs efficiently and robustly.
2008_ICASSP_LlagosterasEtAl_BAVSS-authorversion.pdf (621.13 Ko) Télécharger le fichier
inria-00544971 , version 1 (27-01-2011)
Anna Llagostera Casanovas, Gianluca Monaci, Pierre Vandergheynst, Rémi Gribonval. Blind Audiovisual Source Separation Based on Redundant Representations. Acoustics, Speech and Signal Processing, 2008. ICASSP 2008. IEEE International Conference on,, Apr 2008, Las Vegas, Nevada, United States. pp.1841 -1844, ⟨10.1109/ICASSP.2008.4517991⟩. ⟨inria-00544971⟩
220 Consultations
364 Téléchargements
