VeTo: An Exploit Prevention Language from Known Vulnerabilities in SIP Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present VeTo a language to specify protection rules for VoIP systems, supported by the SecSip prevention framework. VeTo offers a unique way to specify both vulnerabil- ities and countermeasures to protect SIP services against known vulnerabilities. We illustrate the applicability of the language through the specification of several known attacks and assess its efficiency through a target testbed.
PID1075963.pdf (214.28 Ko) Télécharger le fichier
inria-00544976 , version 1 (09-12-2010)
Abdelkader Lahmadi, Olivier Festor. VeTo: An Exploit Prevention Language from Known Vulnerabilities in SIP Services. IEEE/IFIP Network Operations and Management Symposium - NOMS 2010, Apr 2010, Osaka, Japan. pp.216-223, ⟨10.1109/NOMS.2010.5488464⟩. ⟨inria-00544976⟩
85 Consultations
276 Téléchargements
