Gradient Flows for Optimizing Triangular Mesh-based Surfaces: Applications to 3D Reconstruction Problems dealing with Visibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2011
This article tackles the problem of using variational methods for evolving 3D deformable surfaces. We give an overview of gradient descent flows when the surface is represented by a triangular mesh-based surface, and we detail the gradients of two generic energy functionals which embody a number of energies used in mesh processing and computer vision. In particular, we show how to rigorously account for visibility in the surface optimization process. We present different applications including 3D reconstruction from multiple views for which the visibility is fundamental. The gradient correctly takes into account the visibility changes that occur when a surface moves; this forces the contours generated by the reconstructed surface to perfectly match with the apparent contours in the input images.
DP-IJCV-2010.pdf (4.17 Mo) Télécharger le fichier
Format : Figure, Image
inria-00546105 , version 1 (24-05-2011)
Amael Delaunoy, Emmanuel Prados. Gradient Flows for Optimizing Triangular Mesh-based Surfaces: Applications to 3D Reconstruction Problems dealing with Visibility. International Journal of Computer Vision, 2011, 95 (2), pp.100-123. ⟨10.1007/s11263-010-0408-9⟩. ⟨inria-00546105⟩
728 Consultations
2661 Téléchargements
