Nudelman interpolation, parametrizations of lossless functions and balanced realizations. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2007
We investigate the parametrization issue for discrete-time stable all-pass multivariable systems by means of a Schur algorithm involving a Nudelman interpolation condition. A recursive construction of balanced realizations is associated with it, that possesses a very good numerical behavior. Several atlases of charts or families of local parametrizations are presented and for each atlas a chart selection strategy is proposed. The last one can be viewed as a nice mutual encoding property of lossless functions and turns out to be very efficient. These parametrizations allow for solving optimization problems within the fields of system identification and optimal control.
Nudelman_r2.pdf (436.6 Ko) Télécharger le fichier
inria-00546743 , version 1 (15-12-2010)
Jean-Paul Marmorat, Martine Olivi. Nudelman interpolation, parametrizations of lossless functions and balanced realizations.. Automatica, 2007, 43, pp.1329-1338. ⟨10.1016/j.automatica.2007.01.020⟩. ⟨inria-00546743⟩
158 Consultations
120 Téléchargements
