List-decoding of binary Goppa codes up to the binary Johnson bound - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We study the list-decoding problem of alternant codes, with the notable case of classical Goppa codes. The major consideration here is to take into account the size of the alphabet, which shows great influence on the list-decoding radius. This amounts to compare the \emph{generic} Johnson bound to the \emph{$q$-ary} Johnson bound. This difference is important when $q$ is very small. Essentially, the most favourable case is $q=2$, for which the decoding radius is greatly improved, notably when the relative minimum distance gets close to $1/2$. Even though the announced result, which is the list-decoding radius of binary Goppa codes, is new, it can be rather easily made up from previous sources (V.~ Guruswami, R.~M.~Roth and I.~Tal, R~.M.~Roth), which may be a little bit unknown, and in which the case of binary Goppa codes has apparently not been thought at. Only D.~J.~Bernstein treats the case of binary Goppa codes in a preprint. References are given in the introduction. We propose an autonomous treatment and also a complexity analysis of the studied algorithm, which is quadratic in the blocklength $n$, when decoding at some distance of the relative maximum decoding radius, and in $O(n^7)$ when reaching the maximum radius.
Nous étudions le décodage en liste des codes alternants, dont notamment les codes de Goppa classiques. La considération majeure est de prendre en compte la taille de l'alphabet, qui influe sur la capacité de correction, surtout dans le cas de l'alphabet binaire. Cela revient à comparer la borne de Johnson que nous appelons générique, à la borne de Johnson que nous appelons $q$-aire, qui prend en compte la taille $q$ du corps. Cette différence est d'autant plus sensible que $q$ est petit. Essentiellement, le cas le plus favorable est celui de l'alphabet binaire pour lequel on peut augmenter significativement le rayon du décodage en liste. Et ce, d'autant plus que la distance minimale relative construite du code alternant binaire est proche de $1/2$. Bien que le résultat annoncé ici, à savoir le rayon de décodage en liste des codes de Goppa binaires, soit nouveau, il peut assez facilement être déduit de sources relativement peu connues (V.~ Guruswami, R.~M.~Roth and I.~Tal, R~.M.~Roth) et dont les auteurs n'ont apparemment pas pensé à aborder les codes de Goppa binaires. Seul D.~J.~Bernstein a traité le décodage en liste des codes de Goppa dans une prépublication. Les références sont données dans l'introduction. Nous proposons un contenu autonome, et aussi une analyse de la complexité de l'algorithme étudié, qui est quadratique en la longueur $n$ du code, si on se tient à distance du rayon relatif de décodage maximal, et en $O(n^7)$ pour le rayon de décodage maximal.
RR-7490.pdf (329.23 Ko) Télécharger le fichier
inria-00547106 , version 1 (15-12-2010)
  • HAL Id : inria-00547106 , version 1
  • ARXIV : 1012.3439
Daniel Augot, Morgan Barbier, Alain Couvreur. List-decoding of binary Goppa codes up to the binary Johnson bound. [Research Report] RR-7490, INRIA. 2010, pp.23. ⟨inria-00547106⟩
263 Consultations
273 Téléchargements
