Ensemble forecast of analyses: Coupling data assimilation and sequential aggregation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Année : 2010
er based on past observations and past forecasts. This approach has several limitations: the weights are computed only at the locations and for the variables that are observed, and the observational errors are typically not accounted for. This paper introduces a way to address these limitations by coupling sequential aggregation and data assimilation. The leading idea of the proposed approach is to have the aggregation procedure forecast the forthcoming analyses, produced by a data assimilation method, instead of forecasting the observations. The approach is therefore referred to as ensemble forecasting of analyses. The analyses, which are supposed to be the best a posteriori knowledge of the model's state, adequately take into account the observational errors and they are naturally multivariable and distributed in space. The aggregation algorithm theoretically guarantees that, in the long run and for any component of the model's state, the ensemble forecasts approximate the analyses at least as well as the best constant (in time) linear combination of the ensemble members. In this sense, the ensemble forecasts of the analyses optimally exploit the information contained in the ensemble. The method is tested for ground-level ozone forecasting, over Europe during the full year 2001, with a twenty-member ensemble. In this application, the method proves to perform well with 28% reduction in RMSE compared to a reference simulation, to be robust in time and space, and to reproduce many spatial patterns found in the analyses only.
Mv-jgr-2010.pdf (436.75 Ko) Télécharger le fichier
inria-00547903 , version 1 (17-12-2010)
Vivien Mallet. Ensemble forecast of analyses: Coupling data assimilation and sequential aggregation. Journal of Geophysical Research, 2010, 115 (D24303), ⟨10.1029/2010JD014259⟩. ⟨inria-00547903⟩
301 Consultations
317 Téléchargements
