Project/Team LEAR : Learning and Recognition in Vision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2003
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
LEAR is part of the GRAVIR/IMAG laboratory, a Joint Research Unit of INRIA, the Centre National de Recherche Scientifique (CNRS), the Institut National Polytechnique de Grenoble (INPG) and the Université Joseph Fourier (UJF). LEAR was created officially on 1st July 2003, but this report summarizes the activities of its members throughout all of 2003.
lear2003.pdf (4.45 Mo) Télécharger le fichier
inria-00548222 , version 1 (20-12-2010)
  • HAL Id : inria-00548222 , version 1
Cordelia Schmid. Project/Team LEAR : Learning and Recognition in Vision. [Technical Report] 2003, pp.31. ⟨inria-00548222⟩
118 Consultations
211 Téléchargements
