Selection of Scale-Invariant Parts for Object Class Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We introduce a novel method for constructing and selecting scale-invariant object parts. Scale-invariant local descriptors are first grouped into basic parts. A classifier is then learned for each of these parts, and feature selection is used to determine the most discriminative ones. This approach allows robust pan detection, and it is invariant under scale changes-that is, neither the training images nor the test images have to be normalized. The proposed method is evaluated in car detection tasks with significant variations in viewing conditions, and promising results are demonstrated. Different local regions, classifiers and feature selection methods are quantitatively compared. Our evaluation shows that local invariant descriptors are an appropriate representation for object classes such as cars, and it underlines the importance of feature selection.
dorko_iccv03.pdf (735.28 Ko) Télécharger le fichier
inria-00548234 , version 1 (20-12-2010)
Gyuri Dorkó, Cordelia Schmid. Selection of Scale-Invariant Parts for Object Class Recognition. 9th International Conference on Computer Vision (ICCV '03), Oct 2003, Nice, France. pp.634--640, ⟨10.1109/ICCV.2003.1238407⟩. ⟨inria-00548234⟩
303 Consultations
746 Téléchargements
