Affine invariant retrieval and classification of texture images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Année : 2003
In this paper, we proposed a new method of extracting affine invariant texture signatures for content-based affine invariant image retrieval (CBAIR). The algorithm discussed in this paper exploits the spectral signatures of texture images. Based on spectral representation of affine transform, anisotropic scale invariant signatures of orientation spectrum distributions are extracted. Peaks distribution vector (PDV) obtained from signature distributions captures texture properties invariant to affine transform. The PDV is used to measure the similarity between textures. Extensive experimental results are included to demonstrate the performance of the method in texture classification and CBAIR.
PR2003.pdf (366.48 Ko) Télécharger le fichier
inria-00548241 , version 1 (20-12-2010)
  • HAL Id : inria-00548241 , version 1
Jianguo Zhang, Tieniu Tan. Affine invariant retrieval and classification of texture images. Pattern Recognition, 2003, 36 (3), pp.215--223. ⟨inria-00548241⟩
64 Consultations
111 Téléchargements
