Invariant texture segmentation via circular gabor filter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
In this paper, we focus on invariant texture segmentation, and propose a new method using circular Gabor filters (CGF) for rotation invariant texture segmentation. The traditional Gabor function is modified into a circular symmetric version. The rotation invariant texture features are achieved via the channel output of the CGF. A new scheme of the selection of Gabor parameters is also proposed for texture segmentation. Experiments show the efficacy of this method
ICPR_857.pdf (145.29 Ko) Télécharger le fichier
inria-00548247 , version 1 (20-12-2010)
Jianguo Zhang, Tieniu Tan. Invariant texture segmentation via circular gabor filter. Proceedings of the 16th IAPR International Conference on Pattern Recognition (ICPR), Aug 2002, Quebec, Canada. pp.901--904, ⟨10.1109/ICPR.2002.1048450⟩. ⟨inria-00548247⟩
113 Consultations
5220 Téléchargements
