Plane + Parallax, Tensors and Factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We study the special form that the general multi-image tensor formalism takes under the plane + parallax decomposition, including matching tensors and constraints, closure and depth recovery relations, and inter-tensor consistency constraints. Plane + parallax alignment greatly simplifies the algebra, and uncovers the underlying geometric content. We relate plane + parallax to the geometry of translating, calibrated cameras, and introduce a new parallax-factorizing projective reconstruction method based on this. Initial plane + parallax alignment reduces the problem to a single rank-one factorization of a matrix of rescaled parallaxes into a vector of projection centres and a vector of projective heights above the reference plane. The method extends to 3D lines represented by via-points and 3D planes represented by homographies.
Triggs-eccv00.pdf (141.19 Ko) Télécharger le fichier
Triggs-eccv00-talk.pdf (69.72 Ko) Télécharger le fichier
Format : Autre
inria-00548289 , version 1 (20-12-2010)
Bill Triggs. Plane + Parallax, Tensors and Factorization. 6th European Conference on Computer Vision (ECCV '00), Jun 2000, Dublin, Ireland. pp.522--538, ⟨10.1007/3-540-45054-8_34⟩. ⟨inria-00548289⟩
191 Consultations
477 Téléchargements
