Relative 3D Reconstruction Using Multiple Uncalibrated Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The International Journal of Robotics Research Année : 1995
In this article we show how relative 3D reconstruction from point correspondences of multiple uncalibrated images can be achieved through reference points. The original contributions with respect to related works in the field are mainly a direct global method for relative 3D reconstruction and a geometric method to select a correct set of reference points among all im age points. Experimental results from both simulated and real image sequences are presented, and robustness of the method and reconstruction precision of the results are discussed.
ijrr95_1.pdf (473.58 Ko) Télécharger le fichier
inria-00548396 , version 1 (31-05-2011)
Roger Mohr, Long Quan, Françoise Veillon. Relative 3D Reconstruction Using Multiple Uncalibrated Images. The International Journal of Robotics Research, 1995, 14 (6), pp.619--632. ⟨10.1177/027836499501400607⟩. ⟨inria-00548396⟩
225 Consultations
1975 Téléchargements
