Maintaining Stereo Calibration by Tracking Image Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1993
An important problem in active 3-D vision is updating the camera calibration matrix as the focus, aperture, zoom or vergence angle of the cameras changes dynamically. Techniques are presented to compute the projection matrix from five-and-a-half points in a scene without matrix inversion, and to correct the projective transformation matrix by tracking reference points. The authors' experiments show that a change of focus can be corrected by an affine transform obtained by tracking three points. For a change in camera vergence, a projective correction, based on tracking four image points, is slightly more precise than an affine correction matrix. It is shown how stereo reconstruction makes it possible to `hop' a reference frame from one object to another. Any set of four non-coplanar points in the scene may define such a reference frame. It is shown how to keep the reference frame locked onto a set of four points as a stereo head is translated or rotated. These techniques make it possible to reconstruct the shape of an object in in its intrinsic coordinates without having to match new observations to a partially reconstructed description.
cvpr.93.pdf (49.35 Ko) Télécharger le fichier
inria-00548428 , version 1 (04-01-2011)
James L. Crowley, Philippe Bobet, Cordelia Schmid. Maintaining Stereo Calibration by Tracking Image Points. International Conference on Computer Vision & Pattern Recognition (CVPR '93), Jun 1993, New York, United States. pp.483--488, ⟨10.1109/CVPR.1993.341086⟩. ⟨inria-00548428⟩
287 Consultations
158 Téléchargements
