Hierarchical Part-Based Visual Object Categorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Guillaume Bouchard
  • Fonction : Auteur
  • PersonId : 874970
Bill Triggs
We propose a generative model that codes the geometry and appearance of generic visual object categories as a loose hierarchy of parts, with probabilistic spatial relations linking parts to subparts, soft assignment of subparts to parts, and scale invariant keypoint based local features at the lowest level of the hierarchy. The method is designed to efficiently handle categories containing hundreds of redundant local features, such as those returned by current key-point detectors. This robustness allows it to outperform constellation style models, despite their stronger spatial models. The model is initialized by robust bottom-up voting over location-scale pyramids, and optimized by expectation-maximization. Training is rapid, and objects do not need to be marked in the training images. Experiments on several popular datasets show the method's ability to capture complex natural object classes.
Bouchard-cvpr05.pdf (459.85 Ko) Télécharger le fichier
inria-00548513 , version 1 (20-12-2010)
Guillaume Bouchard, Bill Triggs. Hierarchical Part-Based Visual Object Categorization. IEEE Conference on Computer Vision & Pattern Recognition (CPRV '05), Jun 2005, San Diego, United States. pp.710--715, ⟨10.1109/CVPR.2005.174⟩. ⟨inria-00548513⟩
410 Consultations
446 Téléchargements
