A comparison of affine region detectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2005
The paper gives a snapshot of the state of the art in affine covariant region detectors, and compares their performance on a set of test images under varying imaging conditions. Six types of detectors are included: detectors based on affine normalization around Harris (Mikolajczyk and Schmid, 2002; Schaffalitzky and Zisserman, 2002) and Hessian points (Mikolajczyk and Schmid, 2002), a detector of ‘maximally stable extremal regions', proposed by Matas et al. (2002); an edge-based region detector (Tuytelaars and Van Gool, 1999) and a detector based on intensity extrema (Tuytelaars and Van Gool, 2000), and a detector of ‘salient regions', proposed by Kadir, Zisserman and Brady (2004). The performance is measured against changes in viewpoint, scale, illumination, defocus and image compression. The objective of this paper is also to establish a reference test set of images and performance software, so that future detectors can be evaluated in the same framework.
affine_ijcv05.pdf (7.97 Mo) Télécharger le fichier
inria-00548528 , version 1 (20-12-2010)
Krystian Mikolajczyk, Tinne Tuytelaars, Cordelia Schmid, Andrew Zisserman, Jiri Matas, et al.. A comparison of affine region detectors. International Journal of Computer Vision, 2005, 65 (1/2), pp.43--72. ⟨10.1007/s11263-005-3848-x⟩. ⟨inria-00548528⟩
3610 Consultations
3453 Téléchargements
