An efficient method to compute the inverse jacobian matrix in visual servoing An efficient method to compute the inverse jacobian matrix in visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
no abstract
LDJC04.pdf (139 Ko) Télécharger le fichier
inria-00548543 , version 1 (20-12-2010)
  • HAL Id : inria-00548543 , version 1
Jean-Thierry Lapresté, Michel Dhome, Frédéric Jurie, François Chaumette. An efficient method to compute the inverse jacobian matrix in visual servoing An efficient method to compute the inverse jacobian matrix in visual servoing. International Conference on Robotics and Automation, 2004, undef, Samoa. ⟨inria-00548543⟩
265 Consultations
1667 Téléchargements
