Boundary conditions for Young - van Vliet recursive filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2006
Bill Triggs
Michaël Sdika
Young and van Vliet have designed computationally efficient methods for approximating Gaussian-based convolutions by running a recursive infinite-impulse-response (IIR) filter forward over the input signal, then running a second IIR filter backward over the first filter's output. To transition between the two filters, they use a suboptimal heuristic that produces significant amplitude and phase distortion for all points within about three standard deviations of the right-hand boundary. In this correspondence, a simple linear transition rule that eliminates this distortion is derived.
TS06.pdf (113.77 Ko) Télécharger le fichier
inria-00548616 , version 1 (20-12-2010)
Bill Triggs, Michaël Sdika. Boundary conditions for Young - van Vliet recursive filtering. IEEE Transactions on Signal Processing, 2006, 54 (6), pp.2365 - 2367. ⟨10.1109/TSP.2006.871980⟩. ⟨inria-00548616⟩
244 Consultations
518 Téléchargements
