EP for Efficient Stochastic Control with Obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of continuous stochastic optimal control in the presence of hard obstacles. Due to the non-smooth character of the obstacles, the traditional approach using dynamic programming in combination with function approximation tends to fail. We consider a recently introduced special class of control problems for which the optimal control computation is reformulated in terms of a path integral. The path integral is typically intractable, but amenable to techniques developed for approximate inference.We argue that the variational approach fails in this case due to the nonsmooth cost function. Sampling techniques are simple to implement and converge to the exact results given enough samples. However, the infinite cost associated with hard obstacles renders the sampling procedures inefficient in practice. We suggest Expectation Propagation (EP) as a suitable approximation method, and compare the quality and efficiency of the resulting control with an MC sampler on a car steering task and a ball throwing task.We conclude that EP can solve these challenging problems much better than a sampling approach.
MVK10.pdf (177.91 Ko) Télécharger le fichier
Format : Figure, Image
inria-00548631 , version 1 (20-12-2010)
Thomas Mensink, Jakob Verbeek, Bert Kappen. EP for Efficient Stochastic Control with Obstacles. ECAI 2010 - 19th European Conference on Artificial Intelligence, Aug 2010, Lisbon, Portugal. pp.675-680, ⟨10.3233/978-1-60750-606-5-675⟩. ⟨inria-00548631⟩
315 Consultations
273 Téléchargements
