Fast and Robust Object Segmentation with the Integral Linear Classifier - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose an efficient method, built on the popular Bag of Features approach, that obtains robust multiclass pixel level object segmentation of an image in less than 500ms, with results comparable or better than most state of the art methods. We introduce the Integral Linear Classifier (ILC), that can readily obtain the classification score for any image sub-window with only 6 additions and 1 product by fusing the accumulation and classification steps in a single operation. In order to design a method as efficient as possible, our building blocks are carefully selected from the quickest in the state of the art. More precisely, we evaluate the performance of three popular local descriptors, that can be very efficiently computed using integral images, and two fast quantization methods: the Hierarchical K-Means, and the Extremely Randomized Forest. Finally, we explore the utility of adding spatial bins to the Bag of Features histograms and that of cascade classifiers to improve the obtained segmentation. Our method is compared to the state of the art in the difficult Graz-02 and PASCAL 2007 Segmentation Challenge datasets.
aldavert_ILC.pdf (2.59 Mo) Télécharger le fichier
Format : Figure, Image
inria-00548642 , version 1 (20-12-2010)
David Aldavert, Arnau Ramisa, Ricardo Toledo, Ramon Lopez de Mantaras. Fast and Robust Object Segmentation with the Integral Linear Classifier. CVPR 2010 - 23rd IEEE Conference on Computer Vision & Pattern Recognition, Jun 2010, San Francisco, United States. pp.1046-1053, ⟨10.1109/CVPR.2010.5540098⟩. ⟨inria-00548642⟩
340 Consultations
325 Téléchargements
