Tile QR Factorization with Parallel Panel Processing for Multicore Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To exploit the potential of multicore architectures, recent dense linear algebra libraries have used tile algorithms, which consist in scheduling a Directed Acyclic Graph (DAG) of tasks of fine granularity where nodes represent tasks, either panel factorization or update of a block-column, and edges represent dependencies among them. Although past approaches already achieve high performance on moderate and large square matrices, their way of processing a panel in sequence leads to limited performance when factorizing tall and skinny matrices or small square matrices. We present a new fully asynchronous method for computing a QR factorization on shared-memory multicore architectures that overcomes this bottleneck. Our contribution is to adapt an existing algorithm that performs a panel factorization in parallel (named Communication-Avoiding QR and initially designed for distributed-memory machines), to the context of tile algorithms using asynchronous computations. An experimental study shows significant improvement (up to almost 10 times faster) compared to state-of-the-art approaches. We aim to eventually incorporate this work into the Parallel Linear Algebra for Scalable Multi-core Architectures (PLASMA) library.
tile-caqr-ipdps.pdf (313.98 Ko) Télécharger le fichier
inria-00548899 , version 1 (20-12-2010)
  • HAL Id : inria-00548899 , version 1
Bilel Hadri, Hatem Ltaief, Emmanuel Agullo, Jack Dongarra. Tile QR Factorization with Parallel Panel Processing for Multicore Architectures. 24th IEEE International Parallel and Distributed Processing Symposium (IPDPS 2010), Apr 2010, Atlanta, United States. ⟨inria-00548899⟩
Collections
CNRS INRIA INRIA2
248 Consultations
466 Téléchargements
