inria-00549107, version 1
A Kalman-Filter-Based Method for Pose Estimation in Visual Servoing
F. Janabi-Sharifi a, 1M. Marey 2
IEEE Trans. on Robotics 26, 5 (2010) 939-947
Résumé : The problem of estimating position and orientation (pose) of an object in real time constitutes an important issue for vision-based control of robots. Many vision-based pose-estimation schemes in robot control rely on an extended Kalman filter (EKF) that requires tuning of filter parameters. To obtain satisfactory results, EKF-based techniques rely on known noise statistics, initial object pose, and sufficiently high sampling rates for good approximation of measurement-function linearization. Deviations from such assumptions usually lead to degraded pose estimation during visual servoing. In this paper, a new algorithm, namely iterative adaptive EKF (IAEKF), is proposed by integrating mechanisms for noise adaptation and iterative-measurement linearization. The experimental results are provided to demonstrate the superiority of IAEKF in dealing with erroneous a priori statistics, poor pose initialization, variations in the sampling rate, and trajectory dynamics.
- a – Ryerson University
- 1 : Ryerson University
- Ryerson University
- 2 : LAGADIC (INRIA - IRISA)
- CNRS : UMR6074 – INRIA – Université de Rennes 1
- Domaine : Informatique/Robotique
- inria-00549107, version 1
- http://hal.inria.fr/inria-00549107
- oai:hal.inria.fr:inria-00549107
- Contributeur : Eric Marchand
- Déposé pour le compte de :
- Soumis le : Mardi 21 Décembre 2010, 11:52:26
- Dernière modification le : Mardi 21 Décembre 2010, 11:52:29
Exporter
