PushMenu: Extending Marking Menus for Pressure-Enabled Input Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Several approaches have been proposed to increase the breadth of standard Marking Menus over the 8 item limit, most of which have focused on the use of the standard 2D input space (x-y). We present Push Menu, an extension of Marking Menu that takes advantage of pressure input as a third input dimension to increase menu breadth. We present the results of a preliminary experiment that validates our design and shows that Push Menu users who are neither familiar with pen-based interfaces nor continuous pressure control can handle up to 20 items reliably. We also discuss the implications of these results for using Push Menu in user in- terfaces and for improving its design.
PushMenu-RR2008.pdf (944.72 Ko) Télécharger le fichier
inria-00550597 , version 1 (29-12-2010)
  • HAL Id : inria-00550597 , version 1
Stéphane Huot, Mathieu Nancel, Michel Beaudouin-Lafon. PushMenu: Extending Marking Menus for Pressure-Enabled Input Devices. [Research Report] LRI-RR1502, 2008, pp.4. ⟨inria-00550597⟩
411 Consultations
189 Téléchargements
