Gametocytes infectiousness to mosquitoes: variable selection using random forests, and zero inflated models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Malaria control strategies aiming at reducing disease transmission intensity may impact both oocyst intensity and infection prevalence in the mosquito vector. Thus far, mathematical models failed to identify a clear relationship between Plasmodium falciparum gametocytes and their infectiousness to mosquitoes. Natural isolates of gametocytes are genetically diverse and biologically complex. Infectiousness to mosquitoes relies on multiple parameters such as density, sex-ratio, maturity, parasite genotypes and host immune factors. In this article, we investigated how density and genetic diversity of gametocytes impact on the success of transmission in the mosquito vector. We analyzed data for which the number of covariates plus attendant interactions is at least of order of the sample size, precluding usage of classical models such as general linear models. We then considered the variable importance from random forests to address the problem of selecting the most influent variables. The selected covariates were assessed in the zero inflated negative binomial model which accommodates both over-dispersion and the sources of non infected mosquitoes. We found that the most important covariates related to infection prevalence and parasite intensity are gametocyte density and multiplicity of infection.
RR-7497.pdf (390.78 Ko) Télécharger le fichier
inria-00550980 , version 1 (01-01-2011)
inria-00550980 , version 2 (04-01-2011)
inria-00550980 , version 3 (21-02-2011)
Robin Genuer, Isabelle Morlais, Wilson Toussile. Gametocytes infectiousness to mosquitoes: variable selection using random forests, and zero inflated models. [Research Report] RR-7497, INRIA. 2011. ⟨inria-00550980v3⟩
328 Consultations
285 Téléchargements
