Enabling more optimizations in GRAPHITE: ignoring memory-based dependences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Data-dependences need to be analyzed to guarantee the legality of a loop transformations and parallelization. But many dependences are spurious memory-based dependences: they are induced by storing values in the same memory location. Spurious dependences reduce the degrees of freedom in loop transformations and parallelization. The effective handling of spurious data-dependences in GIMPLE is essential for the effectiveness of polyhedral compilation in GCC. We show that most memory-based-dependences induced by the gimplification can be ignored, rather than scalar/array expanded. Our method relies on an extension of the violated-dependence-analysis technique implemented in GRAPHITE. It has a minimal impact on compilation time and guarantees that we are not loosing any transformation opportunity compared to a source-to-source compilers. We will detail the algorithm, the current state of the implementation and the future plans.
trifunovic.pdf (171.61 Ko) Télécharger le fichier
inria-00551509 , version 1 (04-01-2011)
  • HAL Id : inria-00551509 , version 1
Konrad Trifunovic, Albert Cohen. Enabling more optimizations in GRAPHITE: ignoring memory-based dependences. Proceedings of the 8th GCC Developper's Summit, Oct 2010, Ottawa, Canada. ⟨inria-00551509⟩
115 Consultations
182 Téléchargements
