Software Pipelining and Register Pressure in VLIW Architectures: Preconditionning Data Dependence Graphs is Experimentally Better Than Lifetime-Sensitive Scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Embedding register-pressure control in software pipelining heuristics is the dominant approach in modern back-end compilers. However, aggressive attempts at combining resource and register constraints in software pipelining have failed to scale to real-life loops, leaving weaker heuristics as the only practical solutions. We propose a decoupled approach where register pressure is controlled before scheduling, and evaluate its effectiveness in combination with three representative software pipelining algorithms. We present conclusive experiments in a production compiler on a wealth of media processing and general purpose benchmarks.
SubmitODES2010.pdf (67.54 Ko) Télécharger le fichier
brault_slides.pdf (962.01 Ko) Télécharger le fichier
Format : Autre
inria-00551515 , version 1 (04-01-2011)
  • HAL Id : inria-00551515 , version 1
Frédéric Brault, Benoît Dupont-De-Dinechin, Sid Touati, Albert Cohen. Software Pipelining and Register Pressure in VLIW Architectures: Preconditionning Data Dependence Graphs is Experimentally Better Than Lifetime-Sensitive Scheduling. 8th Workshop on Optimizations for DSP and Embedded Systems (ODES'10), Apr 2010, Toronto, Canada. ⟨inria-00551515⟩
301 Consultations
371 Téléchargements
