Building factorized TAGs with meta-grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Highly compacted TAGs may be built by allowing subtree factorization operators within the elementary trees. While hand-crafting such trees remains possible, a better option arises from a coupling with meta-grammar descriptions. The approach has been validated by the development of FRMG, a wide-coverage French TAG of only 207 trees.
Mots clés
mgfull.pdf (107.57 Ko) Télécharger le fichier
inria-00551974 , version 1 (05-01-2011)
  • HAL Id : inria-00551974 , version 1
Éric Villemonte de La Clergerie. Building factorized TAGs with meta-grammars. The 10th International Conference on Tree Adjoining Grammars and Related Formalisms - TAG+10, Jun 2010, New Haven, CO, United States. pp.111-118. ⟨inria-00551974⟩
141 Consultations
173 Téléchargements
